How do I install vp side venetians ,pls help :(
Calais666
victoria
VL CALAIS / VP CALAIS
:bomb:
We installed the back fairly easy on the vp calais , very straight forward but these dam side ones ???
Do I have to ale the plastic side part off to fit them in ... I've seen inside pics on the side venetians but can't fit instalment directions
Pls help ...
FXST01
The Grey Man
Perth, WA
VP V6 Exec
Any pictures of the side venetians, they might give us a clue.
psirx7
The side venetians should slide in and fit without any problem.I have upgraded all my VP Executive window trims to VP Calais with Calais rear quarter windows..Initially my quarter window venetians didnt fit as there are two types of plastic interior window trims fitted to VPs.One style has a flatter/longer bottom and in the other style the moulding tapers up to the rear of the quarter window.You need the inner triangle trims with the longer and flat bottom for them to fit..Hope this helps as I just did all this last week and encountered the differences in interior trim..cheers Jason.
Calais666
victoria
Yes this does help .. While we were at at we took out the headlining n going to re do it on Sunday ... At same time I think I must have the other quarter window trims , so the only way they will fit is to cut two narrow holes so the two clips will fit into it and the top section can slide under the plastic :( darn it !!! This vp has almost made me go bonkers being so darn difficult with everything .. But I will fit them damn it !! Lol
Thanks for the reply :))))))
