Jxfwsf
ok, the cable needs to have some slight slack. it's obviously holding the throttle body open slightly (which is wrong).
If it's having trouble starting then it's the ecu trying to relearn the IAC setting.
Reset the ecu.
Slacken it off again but this time when you try to start it hold the go pedal down slightly until it starts, once it's fired and running hold 2000 rpm for 10 seconds or so, this'll reset the iac setting and it should be back to normal afterwards (unless someone has been playing with the throttle butterfly stop screw position then this looks to be the vac leak code issue)
Reset the ecu.
