How to remove centre muffler pipe from cat pipe (urgent)
kylo33710
30
Ballina, NSW
VS Exec 1995
i have recently purchased a Lukey 2.5" cat-back exhaust.
i am 1/2 through installing it and so far i have done:
Removed all bolts from the (is it Phlange?) well anyway all the bolts that hold the gaskets together and i have removed all rubber mounts and kept them in a safe spot.
i am stuck though as the pipe from the centre muffler that goes over the pipe coming from my cat is like it has been welded together, but when i baught the exhaust it said 'only hand tools required'
i pulled as hard as i could and shook like crazy and it just won't come off.. what can i do?
p.s i am going to my mates tonight and wanted to suprise him with it on but at this stage i doubt i will finish it without help from an exhaust guru or shop.
thanks.
kylo33710
30
Ballina, NSW
VS Exec 1995
also forgot to mention i managed to remove the rear muffler VERY easily, still going on the centre..
ephect
Donating Member
VS Acclaim V6
If it was standard ita a straight swap, but if it has been modified before or replaced and welded, U can pull all U want, it ain't coming off.. its either been welded on or it hasn't..
can you take a pic and post it up?
kylo33710
30
Ballina, NSW
VS Exec 1995
sure ill do it right now, i don't know how to identify a weld but it doesn't look like its been welded..
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
There should have been two spring bolts holding the flange to the rear of the cat. It may just be rusted together, pull the muffler sideways and it should separate.
aussieakito
Melbourne, Victoria
H
If you cant tell whether its welded on or not perhaps you shouldn't be fiddling with it.
kylo33710
30
Ballina, NSW
VS Exec 1995
is this ok? i can take a shot further back if you like
kylo33710
30
Ballina, NSW
VS Exec 1995
in the photo above ^ i have removed the phlange bolts and one side of it is just sitting there if you were wondering.
Kiddo
You're serious bro?!
Mitsubishi Colt
Looks like its just rusted together.
