TehFastyOne
- Aug 26, 2005
- 181
- 8
- 0
- Location
- Darwin, NT
- VE SS V Utility
A few people on the forums have asked this question and I don't really blame them, I was also a little bit baffled as to how to get to this speaker. Taking the grill off was something I was apprehensive to do as the fit is really tight and pulling on it felt like it was going to snap.
If you pop the window side of the cover, you need to apply upward pressure on the outer side as you work your way back towards the front of the grill. It will pop out. It is extremely unlikely you will snap the cover as I've done it 3 times to mine and it eventually pops off. Unless you reef it out with those 'pills in the bum' guns you have, it will not snap!
One of the white plastic clips fell down into the dash, just be mindful these clips are a pain in the ass to lose so make sure you recover all of them or the cover won't pop back in properly and it won't look right. Those clips are all over the dash. The dash itself is fairly easy to pull apart as well. There are a bazillion clips so don't be worried about pulling. Chances are it'll pop off. Even the doors pop off with ease, you just need to be persistent.
Here's pictures of the removal (apologies the pictures are not in sequence, the image upload system has a mind of its own):
