How to replace Battery in VE Key ?
greenacc
Searching for the billion
VE Berlina
Supposedly Holden does this at service intervals but I have 3 keys and want to do it myself. How do i open the key ?
pjdm1980
Shut up Jr I'm thinkin!
Geelong, Victoria
E1 GTS BUILD NO# 007, GQ Patrol.
I got mine done by Holden for $16 a key, thought that was pretty reasonable.
veessv
Melbourne SE
VF SS, VE SSV
ok what you need to do is
1. flip open the key
2. insert a flat head small enough to fit in the slot if u can get one that is a perfect size the ezr this will be, with it inserted angle it towards the key part and it should pop and slide away from the key
3. now to pop the top off the keypad kinda ezr just put the flat head into the slot you can see and it will pop off change the batt and your done
greenacc
VE Berlina
Thanks, someone had to know. I dont have flip keys so i guess i start with step 2. ?
MPRSSV
Donating Member
Campbelltown, NSW
05 VZ Exec (Police pack) & 05 CV8Z Monaro
From memory I think the battery is a CR2032 - Quite common, Dick Smith sells them for $4.30...
Joey24
VE Berlina
I have a non-flip key how do I open the key to get to the battery compartment as my battery is nearly dead. I just don't want to break the key. Could someone help and post some instructions as to how I can change the battery.
seasmi
VE SS Sportwagon
As 'veessv' stated in his post, just leave out step 1.
Zerone_V
Lexus IS350 (SL)
Here are some images of where you will need to jam a flat bladed screwdriver to pop the keypad compartment off.
image.php
image.php
image.php
Once you have gotten past that stage, the rest is easy peasy !
