vkwalks39
NUCKING FUTS
- Sep 3, 2007
- 271
- 1
- 0
- Location
- Stawell Vic
- VK V8 / VH V8 / VR V8
G'day guys, I have a small problem...If I was to spend $4k on a 253(red), How much HP, Am I looking at? To compare a 308. Here's what I want to do with my engine.....
Head work --ported, valves IN 1.85 EXH 1.54, Double valves springs,
--Street Terra Roller Rockers 1.65 ratio
Pistons ---Flat tops, moly rings,.020"thou oversize, 10.1 comp,
Lifters ---Anti pump ups, Double timing Chain,
Crow Cam --- 40/80--300-240-109-495", Lumpy idle, good power.Improved heads.
Oil pump ---Semi hi volume.
Quadajet 4 barrel carby. K&N air filter.
Electronic dizzy with MSD Blaster 3d coil.
Pacemakers extractors, comp headers, tri y's manderl bent. 2 1/4" exhaust.
I'm using a trimatic stage 1 with 2800 rpm stally. STD 10 bolt diff 3.08.
Now I just want to Horsepower that I'll be looking at for a 253..Or Will it be better to buy a 308 and spend $4k on it. This will going into my vk. I've already spend money on a 253 but that was rebuild with a mild cam and thats is it. I can used that in my vh.
Cheers Jason....thanks for your help.:whistling
