HP estimate?
Warranty Void
Take it apart? Me? No!
VP Berlina LX V8
Street Machine mag did a 253 build up about 10 years ago, chasing 350 HP and got it quite easily without going mental with cash or mad compression etc. They did offset grind the crank though for more throw. It might be worth googling "street machine 253 build" or "little league 253" or phoning Dandenong Crankshaft reconditioners or regrinders I think they were called, as they did the build and probably still have all the specs.
ari666
250,000 hits
vkwalks39
NUCKING FUTS
Stawell Vic
VK V8 / VH V8 / VR V8
Ari, ok cool thanks for that. Still deciding on what to do? Buy a 308 or do the 253 up?....... ARI, I've got a question for you, My cousins vh brock hasn't been start for about 4.5yrs, the carby is not running probly we are going to put a kit into it, running real rough, and it's blowing out dark black smoke from the exhaust. Do you reckon just give it a GOOD services, and do the timing? Cheers Jason
vkwalks39
NUCKING FUTS
Stawell Vic
Warranty void, I remember that, something like 377hp or something like that! I might have look into that....Cheers
ari666
250,000 hits
my impala hadnt been started in 14 years (so i was told). tipped some fuel down the neck of the carby new battery and fired on about the 3rd crank :D ran like poop tho. changed plugs, cap and rotor. and ran much better. to this day i still have not touched the bottom end, just cleaned it all up, changed cam and lifters, intake and carby and it runs like a dream.
i guess itll depend on how much water has been sitting in the bores.
have a read though here: https://forums.justcommodores.com.a...odify-quadrajets-also-vac-hose-diagram.121828 i tried to cover pretty much everything. if you wanna rebuild the carby on it, it should help you muchly.
vkwalks39
NUCKING FUTS
Stawell Vic
thanks man for your help, will going back to melb on monday to finish of what we started....cheers Jason
Warranty Void
VP Berlina LX V8
I had a search around and found the article on another forum...
"http://www.#################/ases/4.0.5_L4306df7/holden-v8s/27126-little-league-article.html"
Hope this helps mate!
OK I've tried 3 times to put the link in and each time the address turns into ########
This is pissing me off beyond belief.
Warranty Void
VP Berlina LX V8
A
U
S
S
I
E
V
C
O
M
A
U
This is the bit that turns into ######
Warranty Void
VP Berlina LX V8
Why does it turn into ##### I wonder.
