HSV VT 5 Litre vs Standard 5 Litre
Oken
Earth
VY SS
Hey all, im having some issues with my 5 litre in my VR and am looking at putting a VT motor in. I have an auto elec prepared to wire it all up but just wondering whats the difference between a standard VT motor and the HSV 195i/220i?
Also what performance figures should i be looking at with an exhaust, intake and tune on the VT motor?
EDIT: Also hoping to keep my VR's Shift kitted auto
DeViLisanAnGeL
VQ 5L - 12.6@108 stock bottom end & comp
I have read somewhere that the Base VT 179kW motor has a different cam to that of the 195kW HSV donk. The 220i is the 5.7L version.
greenfoam
102
VP Executive R-spec
It's all tune. They are almost indentical in differences to the early 165 vs 185 tunes. But when you stick the motor in the VR you can pretend it has a little cam in it because the roller cam is more sporting than the early one, alot of people do that swap VT into VN-VS
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
The 195 engine has a different cam equivalent to a crane 276 or similar.
the 220 engine is a stroker (5.7) with the sae cam as the 195 engine
Oken
Earth
VY SS
so im better off tracking down a 195i rather than the standard VT motor?
exec24
SA
VY Berlina Series 2
a vt 179 motor is almost complty diffrent to a 195kw
in short a vt 195 motor is a 220 motor minus the stroker crank
exec24
SA
VY Berlina Series 2
oh and all VT motors run Air Flow Meters, and Sequential Injection, whereas VS do not, and the ECU is competly diffrent
POVRTY
building 5L VB TH 400
41
taree nsw
Wm L98 caprice
are the vt ss 5L motors 195? or only hsv spec engnes
