stooge
- Apr 3, 2014
- 3,155
- 3,092
- 113
- Location
- wa
- Turbo Alpaca
Ok, then the Nano isn't likely at fault in pass thru. What about dropping the internet connection mid programming, what effect would you anticipate there? With the Bosch unit, the recommendation is not to use the Wi-Fi or electronic connection between the interface and OBD port and use the supplied cables when programming.
if the internet drops i would not expect it to matter because the required data would be cached before the programming attempt unless gm is really dumb.
if you were using wifi to communicate with the programmer and it dropped out mid programming i would expect a brick which is why with any of the programmers always use cables, wifi is a bad idea imo.
