Increase timer on 'See me home' lights
Super_Sonic
Hamilton
VF2 Sportwagon
So Ive spent a few hours searching but can't see if this has been asked before... apologies if it has.
Just wondering if it's possible to adjust the length if time the exterior lights stay on (when its dark) once the vehicle has been locked.
Pretty sure the function is called 'See me home ', 'follow me home', 'take me home' or something as similarly stalker/creepy as that.
sequal
VFII SSV
Page 105 and 108 of the manual
Entering the Personalisation Menus
1. Press CONFIG to access the Configuration Settings menu or on vehicles with Navigation, press HOME then touch Config screen button.
2. Turn the TUNE/MENU switch to highlight the desired menu item.
3. Press the centre of the TUNE/MENU switch to select the highlighted menu item. The ignition must be in the ON position.
Exit Lighting
This allows the selection of how long the exterior lamps stay on when leaving the vehicle when it is dark outside.
Press the TUNE/MENU switch when Exit Lighting is highlighted. Turn the switch to select Off, 30 Seconds, 1 Minute, or 2 Minutes. Press / BACK to confirm and go back to the last menu.
stooge
wa
Turbo Alpaca
"Take me home lighting" sounds like a button in a ford that you press to guide the tow truck to you.
