Install a single din into a VX
michaelw
Donating Member
46
Newcastle NSW
VX S2
Hi all.
So I have built my steering wheel control to IR converter (JVC only ATM). I have successfully removed the old stereo but now I have to bolt the new one in.
So I'd like to know if there are any good howto's about the place. Mostly I need information on how to remove the side console panels so I can get access to drill some mounting holes.
OR
How much (and where in Newcastle) will it get to get it professionally installed. Bearing in mind I have all the electrical bits and only need mechanical mounting.
OR
If there is a professional installer in the Newcastle/Hunter area that would like to swap an ir converter/ALDL/OBD adaptor for a (basic) install drop me a PM.
Mike
luminex
VX Lumina
hi mate, when i put my first single din in my car, it was a pioneer, the cage that came with the deck was a bit to small for the cage already in the car so i just wedged it in there real tight (Its a real tight fit) and then wedged the deck into that cage and it stayed there by itself, not one screw. sounds a bit dodgy but worked a treat for me. would show u picks but now got a double din dvd headunit
bezz
VK
i did a similar thing in my vt, had to knock the cage out slightly.
holdenboy
Custom Car Stereo Systems
40
Nelson Bay NSW
VR Wagon
Yep the cage is a REAL tight fit, but does fit in there, i usually put a screw on either side though....but its such a tight fit you could get away without them.
Mate im not after a converter but can the job for you, send me a pm.
michaelw
Donating Member
46
Newcastle NSW
VX S2
Thanks, I just was not being brutal enough.
At least this thread might help the next bloke.
Mike
