mtd
- Sep 22, 2010
- 233
- 190
- 43
- Location
- melbourne,VIC
- VE S1 Calais V V8
I'd appreciate if anyone has any ideas on what this problem might be. I've done a heap of reading with similar issues here but no joy.
Vehicle: 2009 S1 Calais V wagon
Lighting OK/working:
- Door puddle lamps
- Front and rear interior dome lights
- Egress lighting all working as normal
- All other external lighting (headlamps/stop/indicator/brake lights OK
Lighting NOT working:
- Map reading lamps - front and rear
- Glove box light
- Boot lamp
- Vanity lamps in sun visors (both sides)
Have replaced boot lamp bulb - no joy
Have checked map reading lamps front - bulbs look fine.
Have switched around 15A fuse for courtesy lights via fuse box front passenger side - (with spare) no joy - and it seems RH indicator would not work if this had gone anyway - but I could have that wrong...
Some of you will remember that I did have the headlining in this vehicle replaced a while ago. I am however, unsure whether I remember them working after this was done. The harness in the dome lighting/sunglass holder area seems OK. Would there be yet another harness up inside the roof left unattached?
What would be the next obvious thing to check? I am no sparky. Trip to an auto-electrician?
- Door puddle lamps
- Glove box light
- Boot lamp
