Irs, LSD. same exhuast?
orthaeeoul
Bunbury
VY Exucutive S2 3.8 2004
iv got a 04 S2 vy excutive with irs, would the cat back fit onto a mates car with an LSD?she has an 03 acclaim. (doesnt know what series)
camstatic
I'm back babeh.
Regional SA
VZ SS
If they're both IRS it'll bolt up, provided it's the same engine. (Might even fit between engines but I'm not sure, haven't been there)
orthaeeoul
Bunbury
its an ecotec. im mostly curious if it will fit if she has LSD...
SAV_117
Donating Member
VE V8 Calais
why would the lsd be in the way
stocky
34
VT onwards every model had IRS.
LSD wouldnt make any difference. exhaust should bolt up fine.
savage1987
Donating Member
www.facebook.com
Every model except the Tonners and a couple of other special ones. All sedan models had IRS :)
LSD is not significantly different (if at all) externally, so if it's going from a VY sedan to another VY sedan with the same motor I'd say you'll be fine.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
If they are both sedans, yes it will fit.
nick_
VY II V6
If it's a series 1, then I believe it wont fit.. Worst case scenario is that it will need to be modified slightly..
-Nick.
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
It will fit regardless.
The series one had a single cat, the series 2 had twin cats, but they had a y pipe that brought the front flange of the exhaust to the same place anyway.
orthaeeoul
Bunbury
cheers fellas, answer's all my questions.
Thanks!
