ShawtyNate
In the feels.
Damn that looks nice. I'm debating weather or not to put foggies on my vn.
Cheers,.The lights are worth doing. Need to have the SS lip though or the front end of your car will look as if its got buck teeth lol. Its a shame the originals are so hard to find thesedays.Damn that looks nice. I'm debating weather or not to put foggies on my vn.
just having a look thru your build thread..
tips for bleeding in brakes is to scuff them up on concrete before you put them in..
Yeah i took them out and scuffed them up. Also used some CRC de-squeak on the rotors. It helped a little bit. But there is still brake squeal when the brakes are cold.
In other news,There is now a T5 manual conversion sitting in the garage awaiting a rebuild and a clutch. good times ahead.
In the meantime Ive also got a corvette servo waiting to go in the TH700 when i get time.
How'd you get the rear wheel arches going man?
Looking good.
To fix the brake squeel take the pads out and cut a groove diagonally across the pad with a hacksaw. This usually works
-1mm thick galv sheet metal,
-a sheet metal folder-thing-apparatus (was at highschool),
-cardboard (cardboard is the best stencil/template material ever),
-angle grinder with a 1mm cutting disk,
-lots of time with a spot welder,
-lots of time fitting, removing, modifying until they were a proper fit. then:
-rivets, touch up paint
-sikaflex
-trolleystrips from a wrecker special
And then guess what? After all of that.. THEN I found out that the VP calais' came out with those as standard!
