looseunit
- Oct 14, 2023
- 21
- 3
- 3
- Age
- 55
- Location
- perth
- 99 vs statesman l67 50th anniversary
Hi ALL
Ok
VS 1999 L67 statesman 50th
Upgrade coil, dfi, leads plugs, 10psi pully,, new crank sensor , oxygen sensor, fuel pressure valve, fuel pump plus more,
before replacing all this it was braking down, stuttering underload, and real bad thru 3000 to 4000
but would drive thru, it
replaced all that , 2 weeks later started again , then DFI stopped working,
Mace replaced DFI and have been great, 2ND one within 2 weeks started the same problem.
Again replaced but straight away its started again ,
No codes , and fuel mix right .
HELP
Ok
HELP
