l67 not running full boost?
l67vscalais
Albury
1997 vs calais l67
Hey guys not sure if this is the right place to post. I have a vs Calais with the l67 engine. Now I've got the following mods 4 inch intake with pod box and filter behind headlight, 87mm yella terra stealth pulley, mace high ratio rockers, pacemaker headers, twin high flow cats into 2.5 inch exhaust.and a mace memcal.should I be seeing more then 5 psi on the boost gauge? Its all hooked up correctly it runs of the supercharger snout port.
Immortality
Staff member
Sth Auck, NZ
Check that the boost bypass valve is functioning correctly.
l67vscalais
Albury
1997 vs calais l67
I have had a good look at it and on the boost valve I see on the bottom port there is no hose connected and there is a screw blocking the port. That can't be right hey? Perhaps the old owner screwed around with the valve? I'm still learning a great deal about these l67s so not sure about the vacuum side of things
SweetWagon
booosted
35
Springwood NSW
VS Berlina Wagon Supercharged
That port needs to breathe, take the screw out, and probably a good idea to wrap some stocking or filtering material around it to stop debris getting in.
l67vscalais
Albury
1997 vs calais l67
Ok so if I take that screw out and work something out for filtering would That fix my low boost issues? The car goes well but I'm not sure I'm getting the correct boost ? Thanks for putting me on the right track :-
chargedvx6
VY SII HBD Calais L67
l67vscalais
Albury
1997 vs calais l67
Yeah I just registered with l67 torque just waiting on approval cheers :)
