l67 statesman
crazstaat
Vs Statesman III
sounds like a metalicy sound coming from the supercharger any ideas on what it could be thanks
HARVZ-6
Riverton sa
VT spac super6
how long has it been doing it?
any noticable changes in performance?
rattling sound can be cause by either worn bearings causing the rotors to hit, my old charger did this
or in the snout theres a coupler that connects the snout to the rotor gears that could be worn giving the knocking sounds
crazstaat
Vs Statesman III
i think it could be both does it cost much to replace these items ?? cuz its kinda like a knocking and grinding sound
ephect
Donating Member
VS Acclaim V6
could be the rotors have worn on the end plates are are shreading metal thru ur engine
u'll need to feed us a little more info mate, when did it start happening, is it constant, do u do regular servicing, have you changed the oil in the charger? any other info on how the car is performing would be good too.
HARVZ-6
Riverton sa
VT spac super6
how manys ks has it done? any mods ie smaller pulley etc
if you take the belt off running the charger, rock the pully back and forth and check for slop, if theres play moneys on the coupler
from memory theyre about 30bucks whether you replace it yourself or not depends how confident you are.. its a pretty straight forward and easy job to do
if its the bearings theres a chance the rotors have lost their coating aswell then your better of replacing the charger completely
the bearings arnt a 5 minute job you need someone with a press and the knowhow
crazstaat
Vs Statesman III
yea its pretty constant its been doing it since i bought it a couple of months ago i regualary service it its done 238,000 havent checked the supercharger oil
crazstaat
Vs Statesman III
i actually did try that took the belt off its got like a bit of slack when i turn the charger snout left not sure if its supposed to do that
HARVZ-6
Riverton sa
VT spac super6
try giving it a few quick revs and see if it quietens it aswell, with the front bearings gone in myne it would settle with a rev but at a constant speed get louder
crazstaat
Vs Statesman III
na u cant hear it at a constant speed more or less on idle
HARVZ-6
Riverton sa
VT spac super6
in that case its most likely the coupler.. i got 270thousand ksm out of the original bearing in the first charger
The black round piece is the coupler as you can see there is 6 holes in it, 3 holes take by the dowels on the snout shaft
and this is where it goes onto the charger
