rognvald261
I found going from stock discs to big brake setup a huge drag, apparently unsprung rotational mass carries a magical performance penalty that's hard to pin down a clear explanation as to why. Search web, some say is 2x up to 10x factor, but whatever it is it does make a big difference to momentum / torque.
Some example rim weights:
VE Redline Forged rims 12.6 kg all
VF Redline Forged rims 10.7 kg front
VF Redline Forged rims 11.8 kg rear
VFII Redline cast rims 13.83 kg front
VFII Redline cast rims 13.97 kg rear
Vertini Dynasty cast 20“ 14.0 kg front
Vertini Dynasty cast 20“ 14.3 kg rear
DBA T3 5000 Series lightweight two piece rotors have same design and ring mass as the venerable T3 4000 Series but are actually 1.9 kg lighter each corner. Brembo make similar thing too and are fitted to the VF Motorsport edition.
So what seems an innocuous choice of upgrade aftermarket rims and brakes could easily cost you 5.5kg per corner, and if you agree with multiplying due to complicated physics, that's horrendous as even the slightest change in unsprung weight makes a huge difference to acceleration, braking, suspension and handling.
BTW if you have access to the transmission tune, measuring and entering the correct wheel diameter makes for far more predictable hence accurate performance and economy. Ultimately the powertrain tune is based on rear wheel revolutions per km, so 1.5% discrepancy at the wheels can mean accuracy (predictability) is out. +/- 100 RPM may not seem much on the dampened nacho needle inside the dash display but can make a noticeable difference to expected / actual performance, because it is perhaps the most important coefficient.
2010 SS A6 tune uses 478 wheel revolutions per km
2014 SS A6 tune uses 476 wheel revolutions per km
275/35R19 tune should use 471.5
275/30R20 tune should use 473
