losh1971
- Jan 17, 2010
- 22,636
- 22,451
- 113
- Location
- North Tas
- VE Series I SS Ute
Got the stripped thread sorted just now. I was able to use the bench grinder to turn down a drill so it fit in the ext. Had a little trouble trying to stack the helicoil. The threads didn't line up so I had to pull the second helicoil out from the filter side. Stuffed a bolt, so I will either see what Nut's & Bolt's have or I will buy a couple of new gen bolts from Holden. They will be $10ea at Holden, so if Nut's & Bolt's have a 14mm head or 13mm head like factory I will grab them from there. Pretty much sorted and lesson learned about not trying to stack helicoils in the future, unless there is some technique to doing it?
