Deuce
Super Stock
- Feb 5, 2012
- 4,527
- 4,789
- 113
- Location
- Snobs Rock (or so the locals say)
- '94 VR SS V8
As far as springs are concerned, cam degrees don't matter. Lift matters.
You will select springs based on three things.
1) size - this is determined by your head. Not much you will be doing here.
2) valve lift - a dial gauge on top of a pushrod or lifter bucket etc, just to see how much it moves. Spring needs 50thou more travel at installed height than what the valve moves (so don't forget to multiply the cam lift by the rocker ratio)
3) rpm - your Dyno chart shows max rpm set in the tune. Just stick with that and you should be good.
