AmericanGuyInAUte
- Mar 25, 2022
- 137
- 69
- 28
- Age
- 52
- Location
- Sydney
- Ute VS
Hi all... Having a hard time and need help because I'm having a braking problem on my 95 VS Ute.
If I drive normally, everything feels perfect!
If I slam on my brakes during say a panic stop, I lose power brakes or have too little power brakes.
I have no hissing from the booster, no idle change during braking.
Things I've tried. I bought a used Brake Booster (with check valve) and installed it as well as a new brake master cylinder. It's exactly the same. THe booster is some crap plastic.
Question... what is the little brake valve connected to the rear Diff with a little chain do? Could that be causing my problem? I had the diff out to replace bushings.
THANKS!!
THANKS!!
