Low washer fluid warning
ringfeder3
56
Nsw
Ssz crewman, wm caprice, 2018 prado, hq Belmont u
My 2010 Caprice is displaying a 'low washer fluid' warning every few days, despite the reservoir remaining reasonably full.
I can't find a leak but when the error warning is minimised, it says 'HID fluid low' (or similar)...
I top the tank up but the message keeps returning
There has been no fault code logged.
Is there a sensor in the tank that may require replacement??
Both hoses on rear of HID lights look connected.
Fu Manchu
WA.
The only way to get to the bottom of it properly would be to remove the front bar, remove the washer tank. Give it a really good scrub clean. Inspect it. Check for leaks. Inspect the wiring and clean the contacts with CO Contact cleaner.
