craigvk
Banned
- Jun 4, 2005
- 1,981
- 23
- 38
- VK 5L Calais
dolphin14 said:the converter/regulator that i had in the VC had the primer button, but it was worked on a solonoid thru the change-over switch inside the car. Also you may have noticed that the regulator is connected into the heater system. This is because the gas itself needs to be heated before it will ignite properly. Hence the reason it is best to start on petrol then change to LPG when the motor is warm/warming up. As for the primer button flooding the engine this is very tru because it by passes the regulator and gives a burst of "concentrated" LPG thru to the mixer.
Actually it's not that at all. Gas doesn't need to be heated. Cooling fluid or at least water needs to be circulated through the converter, or it will freeze. When LPG enters the atmosphere, the state of it changes. The converter needs fluid circulating through it so it stops it from freezing up. I couldn't start my car once because I had low coolant in the radiator and made the converter freeze.
