BlackoutSteve
- Jan 5, 2014
- 409
- 10
- 18
- Location
- Melbourne
- WH Caprice LS1
Just wondering how long it is taking for others with an LS1 for the engine to warm. "Warm" would be the normal position where the temp needle is between 1/4 & 1/2 on the gauge. ..about one third.
On my SCV6, it's reasonably quick and takes about 5 klms, (about 5 minutes) at normal 60-80 kph speeds for the gauge to read 1/3. Naturally this is nothing more than mild acceleration and cruising.
With the LS1, it takes considerably longer, perhaps 20 klms or more and not go passed a 1/4. It will eventually make it to 1/3, but not after some time.
Question..
Before I pull the old thermostat and replace with a new one, is this much longer warm-up somewhat normal for LS1s?
I'm guessing my thermostat is opening fine, but not fully closing to allow fast warm up.
(Apart from excessive wear & tear, fuel economy is disgusting when the engines are cold. Have you ever watched the "instant fuel consumption" to see how high the numbers go when they're cold?)
Thanks
Question..
Thanks
