VX SS 5.7L High Idle on cold start only 1.9k to 2.0k rpm !!
Demonrt8
33
Egypt
2002 Chevrolet Lumina SS (Holden VX SS Commodore)
what fuel are you using
if ethanol could account for high fuel trims
Egypt shitty fuel man :D
Ron92 some times Ron95
But here the gas stations even mobil1 / total add some ethanol to the mix to higher up the octane number :/
lout
60
Langwarrin Victoria
that should be okay
do you have any way to check the fuel pressure
Demonrt8
33
Egypt
that should be okay
how much psi should i check for engine running or ignition on status from fuel rail nozzle ?
lout
60
Langwarrin Victoria
Demonrt8
33
Egypt
Update ..
I found a vacuum leak under the manifod and by both side of the manifold base doing that by curb cleaner test it idled higher than usual when i spray there .. so i think the 8 intake manifold gaskets took **** on me .. but when i smoke tested vacuum lines no smoke like there is no leaks .. so long story short iam going that route and i have ordered a new gaskets for the manifold then will keep you guys updated after i change them
  • Like
Reactions: Lex
