Ls1 to L76 swap
freefallin
41
UAE
VY Berlina / VZ SS LS1
Got a 05 VZ SS with an LS1 engine...thinking of swapping the engine to an L76 off a VE. Will it be a straight swap, plug and play? Or is there more to it?
Vz SS
ACT
Ve SSV Redline
There is more to it you need to get a converter as throttle body is different the reluctor wheel is different as wellhttp://www.lingenfelter.com/mm5/merchant.mvc?Screen=PROD&Product_Code=L460065397&Store_Code=LPE&Category_Code=C163#.UfGU98saySM
richardpalinkas
Blown Alloytec
Gold Coast
Raptor Impulse VZ SV6
What's wrong with an ls1? Cam, dif gears and hi stall converter will see 11 at the drags.
Kiddo
You're serious bro?!
Mitsubishi Colt
Exactly. Why would you? Seems like you'd be doing it cause you've got nothing else to waste your money on.
Trayner
Fresh prince of Pakky, Gangsta
Gangsta Hundy
What he said ^ spend the money on your current motor and it will be better then the stock L76 and probly cheaper then the conversion would cost
freefallin
41
UAE
Fair nuf. But i gotta change my motor anyway cz of a bad piston ring. The difference between an ls1 and l76 is about $533 over where i am. So i figured if its going to be just a straight swap, might as well get me the 18 extra cubes.
SSV-050
34
VY SS 6 Speed
just cam it:idea3:
