s_ikari2015
Fun IS easier with an 8
- Nov 16, 2007
- 697
- 30
- 28
- Location
- Australia
- '02 Monaro V2 CV8, '90 Toyota Sera
*scratches his head*
ummm... I don't like those dyno figures. Does anybody else think they're way too low for an LS1 considering stock FW is 260KW? (roughly 200 RWKW by most conversions).
"The LS1 was rated at 350 hp (260 kW) and 365 lbf·ft (495 N·m) since 2001 (LS6 Intake)"
Although, given that all dyno KW/HP figures are entirely mathematical as it can't actually be measured, they use formulaes based on the torque measured to come up with a number. The stock numbers used 495Nm at 5000rpm to get 260KW at the flywheel.
So allowing for around 30% loss through the drivetrain (as commonly suggested) the dyno torque should be reading around 380Nm at 5000rpm.
Anyway, looking forward to reading more fuel usage numbers now that you've had the retune. I'm seriously considering a liquid LPG system when costs of both installs and LPG return to more reasonable levels.
EDIT: actually, considering earlier LS1's were rated at 240 odd KW at the flywheel I guess 180rwkw is reasonably close to "stock".... MAFless will boost that sucker though
lol
