m20 n a VK commodore
Ls2_307
VT SS 5.0
vkberlina
VK Madman
41
NSW Central Coast
www.members.westnet.com.au
Yeah should work just fine,
I wount buy a box without inspecting it first though, oyu need to knock the side plate off and check the case hardening isnt coming off the gears. This esp happens on the cluster on 1st gear
Also check for slop in the cluster. These boxes are pretty easy to rebuild, as long as the gears are ok.
When you fill the box with oil use VMX 80.
cheers
Scott
craigvk
Banned
VK 5L Calais
That would suit. If that box came out of a 253, the only difference being is it's a M20 which have different gear ratios in the box compared to the M21. Also the 253 V8 pressure plate and clutch plate are 60mm smaller from memory. I assume your VK is a stock 308?
I actually have a M20 complete without some things which I am looking at sticking in my 308. Funny that my pressure plate and clutch plate are the size for a 308 even though it came out of a 253.
The only other thing you need is a Spigot bush for your crank I think. The speedo cable from the Trimatic will mount in ok I am sure.
vkhawkey
vk commodore
needs a spigot bush when changing from auto to manual in a 202. not sure about the v8s. is that the case as well?
atrail308
RIP King of the Mountain
southside adelaide
V8 VH SL/E 308
go easy on your gear changes tho, ive popped a couple of those m20's...
synoptica
Stripping VK - PM me!
37
SE Suburbs, VIC
No longer a Commodore
I'm looking at sticking one in mine to get rid of the horrid MC6 (Philipino box) - do they take the same clutch as the MC6 and M76?
atrail308
southside adelaide
V8 VH SL/E 308
same flywheel, but different clutch and fork...
synoptica
37
SE Suburbs, VIC
I just called PBR and they reckon they're the same. **** :(
vkberlina
VK Madman
41
NSW Central Coast
The 6cyl boxes ue the same clutch fork, clutch plate as the MC6 & M76 borgwarner boxes. The V8 box has a longer clutch fork, although the spline are the same on the input shaft the V8 used a bigger clutch.
If you want the ultimate clutch plate aligning tool,and you have a rooted M20/M21/MC6/M76 series box laying around get the input shaft out of it and juse it to align your clutch plate.
cheers
Scott
