MACE Manifold Insulator & Plenum Spacer Review
Kernal
NSW
What are the insulators made of??
Immortality
Staff member
Sth Auck, NZ
Trent Nichols
35
Hobart, TAS
vy ute
why didnt you go the 25 mm plenum spacer, is there a reason or cant you go that big on a standard engine
MACE
If the engine isn't running boost going the 25mm plenum spacer hurts engine responsiveness.
Hope this helps
Cheers,
Steve
menace2sobriety
West Auckland
2003 VY soon to be boosted
25mm Manifold Insulator and 12mm Plenum Spacer fitted the other day, took roughly 35 minutes all up ( no dicking around ) + a bit longer to let the GOO set, no need for instructions, everything is very basic
Now at idle with the bonnet open the whole plenum is cool to the touch even when the engine is hot-hot, obviously with the bonnet closed this heats up but is still a lot cooler than the intake
Bottom end torque has increased and has also seemed to increased throughout the entire rev range, if I have the wheels on any angle while taking off with anything over quarter throttle it will start to spin the wheels
No modification was needed for my bonnet
Quick and easy mod to do, for the extra low down torque you pick up, it is worth the money
KustomKulture62
Queensland
2013 Specialized Hardrock Sports Disc 29er
I was thinking the 12mm goes on the bottom and the 25mm on the top, or can one chooses any combination they like.
MACE
Glad to hear that you're happy with the upgrade menace2sobriety :D
For a naturally aspirated ecotec, the ideal combination would be a 12mm plenum spacer and a 25mm manifold insulator. The reverse would be true for a boosted ecotec
If you have any questions please don't hesitate to ask
Kindest Regards,
Steve
RagingDemon
Queensland
2001 Commodore VX Acclaim
I got this kit installed recently for my 2001 VX commodore :) good kit i brought mine from MACE website. Noticible gains, only problems i had was that the top of my engine hits the bonnet when its closed causing the bonnet release to jam. Found out today i can pop my bonnet :( i can see the flex in my bonnet from sitting on the engine :( thinking about cutting a hole in the spongey stuff under the bonnet... Sigh
Immortality
Staff member
Sth Auck, NZ
Hi Mate,
What combination of spacers are you using? do you have the engine cover fitted? Have you fitted new engine mounts?
MACE
Hi
Thank you for your enquiry.
"I got this kit installed recently for my 2001 VX commodore good kit i brought mine from MACE website. Noticible gains, only problems i had was that the top of my engine hits the bonnet when its closed causing the bonnet release to jam. Found out today i can pop my bonnet i can see the flex in my bonnet from sitting on the engine thinking about cutting a hole in the spongey stuff under the bonnet... Sigh"
This is very unusual. If you have fitted new engine mounts this could very well be the problem. If you require any further help on this matter please don't hesitate to contact us directly.
Kindest Regards,
Bill
