kuzman89
You are correct, difference is the shift points in your car cannot be altered, the other tunable auto would change gears at better positions, increasing pickup. However if you can find and install a shift kit, this will help quite a bit. Also, a lot of people report that upgrading the diff in a stock car actually helps the shift points - unsure if this is true or not.
