MACE
- Mar 30, 2008
- 3,187
- 102
- 63
Here are some more specs about this beast
She should be good for a 9.4 at least we think.
As for the mods, a big turbo
ENGINE:
STD block
A.R.P studkit
blanced and blue-printed
come racing 4.2 stroker kit
high ratio roller rockers
custom cam
Custom turbo
MACE reverse plenum
MACE 69mm throttle body
MACE 12mm plenum spacer
MACE 12mm manifold insulator
custom turbo manifolds
msd coil packs
EXHAUST:
50mm extrenal wastagte with screamer pipe
3inch turbo back
2 mufflers
AUTO:
trimatic 3speed
3800 TCE stall convertor
transbrake
2 piece tailshaft
DIFF:
santard IRS
L.S.D
3.4:5 diff gears
FUEL SYSTEM:
2 bosch 044's
custom surge tank
custom ruel rails
840cc injectors
STD fuel reg
SUSPENSION:
90/10 fronts
stock rear shockers
TYRES:
front-moroso DS2 front runners
rear- M&H drag slick 9inch by 27 wall
INTERIOR
auto metter boost guage,oil guage,air/fuel ratio guage, rpm and shiftlight guage,
b&m pro ratchet shifter
kenwood mp3 player
OTHER STUFF:
battery relocated to the boot
STD computer
map sensor
4inc intake to turbo
custom air box
custom catch can
Companies involved in the build
MSC performance
Preston autos and diffs
Full Flight Engineering
MACE Engineering
Electronic automotive
ENGINE:
STD block
A.R.P studkit
custom cam
Custom turbo
MACE reverse plenum
msd coil packs
EXHAUST:
3inch turbo back
2 mufflers
AUTO:
trimatic 3speed
transbrake
2 piece tailshaft
DIFF:
santard IRS
L.S.D
3.4:5 diff gears
FUEL SYSTEM:
2 bosch 044's
custom surge tank
custom ruel rails
840cc injectors
STD fuel reg
SUSPENSION:
90/10 fronts
stock rear shockers
TYRES:
INTERIOR
kenwood mp3 player
OTHER STUFF:
STD computer
map sensor
custom air box
custom catch can
MSC performance
MACE Engineering
