Have you checked shifter selector to the trans shaft?Just done a manual to auto conversion on a vt commodore but when I select gears there’s nothing?
Any help would be super appreciated
Trans fluid is good just seeing now if they have checked the selector shaft thank youHave you checked shifter selector to the trans shaft?
Trans fluid?
Selector to trans shaft connected.Trans fluid is good just seeing now if they have checked the selector shaft thank you
Who did the conversion? & why the conversion?Selector to trans shaft connected.
Selects gears but won’t move?
Did you check fluid level while engine is running?Selector to trans shaft connected.
Not sure who done the conversion it’s a friend of a friendsWho did the conversion? & why the conversion?
Yep they didDid you check fluid level while engine is running?
