Quote Originally Posted by General Xander View Post
Never mind the bottom end, its the top end of the ecotec that dies at high rpm. after 4500 it valve thrashes badly, (from VN to VR) the engine turns off the knock sensor after 3000 coz it can distinguish knocking from valve thrash, then they jus used better sensors. after 4500 all the torque drops off anyway. it would be faster to shift at 4500 then to let it rev up while it does nothing. i would set mine at 4500 to 5000.
The ecotec diden't come out to the vs so was it the same in the eco or just the buick ?
The eco will make power up to wen ever the cam lets it but with the stock bottom end there is no reason it should be revved any more than what the factory limit is set to and holding it on the limiter kiss it as it cuts the fuel and it leans out and as ya know a lean engine goes bang...
