minispool question
kosmoe
VP exec
ive got a vs s pac ute with a wagon diff (previous owner did this)
would it be possible to put in a minispool diff centre?? and how much would i be looking at?
im building a budget drag car so any info would be helpful
soop
Banned
Smithton, Tasmania.
2003 SS Commodore Series II
For a drag car, I would be using a full spool. You can get them off E-bay for around $500.
Will you continue to run the V6?
If so, what are your plans?
What power output are you looking at?
If its a standard ecotec, I wouldn't bother with a spool at all. A standard LSD Will be all you need and can be had for a six pack if you look long enough.
kosmoe
VP exec
currently the engine is stock but am looking to turbo it in the near future so i need a diff that will handle the power
soop
Banned
Smithton, Tasmania.
well you'll need to rebuild the motor long before you have to worry about breaking a diff.
Stock ecotec will take 10psi if its in good nick, so you're not going to bother the diff.
kosmoe
VP exec
so at the end of the day is it possible to change diff centres from a single spinner to make it either lsd, minispooled, or full spooled
kosmoe
VP exec
single spin - one wheel spins one way and the other the other way (when jacked up)
lsd - only grabs both wheels when the power is given
minispool - both wheels are constantly locked (not good for corners or tyre wear)
im not too sure bout the full spool tho
as u can tell i dont have the best knowledge with running gear thats y im posting questions because ive looked for ages and cant find exact answers to my questions
i want to make informed decisions when i do this so im not wasting time, money and effort
soop
Banned
Smithton, Tasmania.
Mini spool is just a smaller weaker version of a full spool.
Its cheap because all it does is replace the spider gears, full spool replaces the whole center.
delcowizzid
on holiday
NZ
в∞ѕтεכ √&
try break a 4 spider minispool aint gonna happen in a hurry no need for full spools
soop
Banned
Smithton, Tasmania.
I'm just going basics atm.
He didn't originally state what power output he was after. So I just went straight for the worst case scenario.
