wetherow
- Jul 24, 2023
- 14
- 9
- 3
- Age
- 36
- Location
- adelaide
- VE series II sv6 SIDI 2011
Hey guys, I have a 2011 Series II sv6 LLT SIDI 3.6L commodore. it's been looked after but has recently developed a significant missfire.
prior to the missfire it had been throwing catalytic converter codes for bank 1 and 2 regularly but never had any issues for almost a year.
fuelled the car up at a different petrol station than usual then the miss fire started. it has codes P0300 P0302 P0304 P0306 and the check engine light flashed when accelerating and is super rough. when starting the car from cold it is OK and idles ok with slight vibration. after it's reached temp and driving around the block it missfires hard and stalls on low revs or slow speed like stopping at an intersection. when trying to start it again it struggles to turn over and sometimes won't turn over like the battery is flat but the battery is fine.
I have replaced the coils and plugs a year ago. I took the air intake off, throttle body, and manifold and found a bit of oil in the big plastic tube coming from the throttle body to the air filter (not sure if that means anything). I've looked at the cams and chains they seem ok, couldn't see any broken valve springs. I have taken the timing chains off and am going to replace them anyway as I thought it might be that. I'm not sure if it is now, any other ideas?
