so its been progressively getting worse to change gears in the car, and seemed to go from crap to downright stupid in an instant not long before i dropped the car off at the panel shop.
i decided to finally pull the gearbox and see what was wrong, and replace some other bits while it was out
got home friday and put it on ramps(who can see my problem, seeing as im removing the gearbox)
so it seems i neglected to take many pics this time round, but heres the important bits.
remove the fork and throwout bearing and im greeted with a nice dusting of bronze EVERYWHERE, a broken fork retainer spring and next to no pivot pin left
heres a comparison of the new oem bmw steel pin(only used on certain cars, m5, 850ci, etc) and the "better wearing than oem plastic" silicon bronze pin that i put in ~80,000ks ago when the engine went in.
the wear on this actually managed to let the throwout bearing spin 90deg and make changing gears shocking
you can see the marks in the fork(theres wear on the proper pads, so it did go in correctly in the first place)
little bit of wear on the pressure plate fingers but still a decent amount of material on the clutch, so it stays for now
gave the box a quick scrub down, as there was fluid all over the top of it at the back, coming from the breather, so rigged up an extended breather for it, checked some of the seals and replaced the end piece on the shifter shaft
also threw some fresh fluid in, last lot wasnt too bad, but hey, its out might as well.
box ready to go back in. guibo and mounts were fine, so didnt bother replacing.
changed the starter motor, original one was starting to feel a bit sad, and again, box is out, was easy enough to do. no pics, its only a starter
and installed my mid section exhaust, been waiting to do this for a while. took some fluffing about, drilling out the front flange bolt holes, modifying brackets.
but its in, lighter, sounds better, high flow cats lets motor breathe a bit more too. unsure how many ks on the mid section i had in there, but i dare say they werent pretty inside.
old pic of exhaust, didnt take pics today, was busy messing with it
overall car feels better to drive, feels more alive with the exhaust, and gears are a dream to change compared to before.
i'll try and get some video of the exhaust once it breaks in a bit more
