today i decided to tackle my diff cover leak, and installing my spherical rtab's.
jacked the car up, by the time i came out of the shed with a drain tray, it had decided to start raining... YAY!! silly victorian weather, it lasted about 10 minutes but didnt stop me crawling under the car and dumping the diff oil
didnt take many pics, so ill fast forward.
diff cover off, and not a single trace of gaskt or rtv apart from around the outside where id smeared some a couple years ago to try and stop to extremely slow leak.
testament to bmw's machining process, ive done over 50,000k since i put the diff in, and its not been enough to leak onto the ground until recently(considering its been sitting at panel shops for ~7 months all up, im not surprised)
for some reason when it was built, the diff guys didnt put anything on. lazy/forgetful/whatever, but i gave the cover a clean and threw some rtv on it. tiny amount of metal on the speedo sensor, but everything else nice and clean, no noticable wear on the gearset, so should be all good
and back in the car, didnt bother completely removing the sway bar(not enough room to remove it without dropping exhaust). i smooshed some more grease on the mount bushes, which looked in good condition still and bolted everyhign back up
while i let the rtv set, i got into the rtabs. of course i still havent bought a removal tool for these, so out with the threaded rod and assortment of plates and sockets. i do have several rather large sockets that work to pull the bush into, but seeing im moving interstate soon, most things are packed.
threw the new rtab's in the freezer for a bit to shrink them, didnt really help, these are a super tight fit!!
and thats all for pics of install. took some effort to get them in, but got there with help of the rattle gun and some alloy plate(was bending the steel plates)
took it for a squirt and the car feels good. i did mark the rtab pockets before removal, and lined them back up as best i could, but will still take it in for an alignment
instead have a couple pics i took when i went for a drive last week. have since reinstalled the boot badge and my roof spoiler, and you'll notice i now have 35% tint all round too
i absolutely love how the car sits now, height is pretty much spot on and i wont be changing it.
