keith reed
- Sep 26, 2010
- 1,317
- 6,123
- 113
- Age
- 76
- Location
- Raceview Qld
- 1983 vh v8 sle 2000 vs v8 ute 2012 ve11 redline
Eureka
Hi KeithEureka
Yes just the plenum cover. I have had a bit of a play with it. Vinegar and water. Fine wet and dry and alluminium polish. It looks better than when I started but as you say lots of work involved. Thanks anywayHi Keith
Its just the plenum cover you want to polish?
What ever you want to polish will eventually go black.
This is why l decided to chrome plate my parts (not the wheels).
They will be easier to clean as well.
I tried 2 pack clear. Didn't like the finish. Some of the clear flaked of the polished surface.
Whatever you decide to do, is up to you.
I suggest getting some pieces of scrap aluminium & practise on that first. That way you don't stuff up what you already have?
Lots of work involved.
I'll be back later for the first lesson.
The only thing l have used, that you have mentioned above is water, on the last wet & dry. Which is 800#grid.Vinegar and water. Fine wet and dry and alluminium polish
Thanks for your help Lex. I might stick to carpentry and get someone to do it for me.The only thing l have used, that you have mentioned above is water, on the last wet & dry. Which is 800#grid.
Depending how rough the casting or moulding is, is how rough the sand paper is.
My plenum lid, l originally started with 80 grid. But wasn't getting the crab out of the metal. So, l got out the 4"angle grinder using 40 grid flap wheel. Started at one end & worked my way down till the other end. Did this a couple of times. You want to surface it evenly (like prepping a body panel) At the end of the job, its like a mirror, flat even no waves.
After the 80 grid l went 60 grid with the flap wheels. After the 60 grid flap wheel, l went to 80 grid by hand & sanding block. Start at one end & work your way down to the other end. Once at the end lift paper & block & go to start. If you drag the paper & block back, (as back & forth like sanding wood) metal dust that sits on the surface will damaging the surface and you wont notice till the final polish. Those scratches will stick out.
After the 80 grid, 120, 180, 240, 320, 400, 600, 800 wet. Remember l was a metal polisher, so l only know what a metal polisher would use.
After the 800 wet, l used what is called a single section 4" close stitched mop on my 4"grinder with an extentsion. With this mop l used a polish called tripoli. Its an aluminium polish. After that l used the same type of mop, but with a finishing polish called green rouge.
Now the object you are polishing is looking like its been chromed.
Tomorrow l will get some pics of the equipment l used.
Here's the pic of my plenum lid again. When its plated l'll post some pics.
Just to add to my previous post, if the job you are dioing isn't that rough, you may only need to start with a lessor grid sandpaper.The only thing l have used, that you have mentioned above is water, on the last wet & dry. Which is 800#grid.
Take it to electroplater & get them to polish & plate it/I might stick to carpentry and get someone to do it for me.
I do know someone here in Ipswich that I have had work done before so I will take it to him.Take it to electroplater & get them to polish & plate it/
If so, keep us in the loop how it comes up & are you happy with it? Don't forget the pics please.
Mirror mirror on the Commodore, Who’s the fairest of them all?The only thing l have used, that you have mentioned above is water, on the last wet & dry. Which is 800#grid.
My plenum lid, l originally started with 80 grid. But wasn't getting the crab out of the metal. So, l got out the 4"angle grinder using 40 grid flap wheel. Started at one end & worked my way down till the other end. Did this a couple of times. You want to surface it evenly (like prepping a car body panel) At the end of the job, its like a mirror, flat even no waves.
