nemesis_adrasteia
better to reign in hell
- Feb 15, 2009
- 672
- 8
- 0
- Location
- longford, victoria
- VR commodore HSV(without all the gay ****)
I wouldn't go any smaller than 87mm on a stocker.
Engine:
L67 (obviously)
Yella Terra Tower of Terror intercooler (52mm plate)
Comp cams XP hot cam
Crow Cams valve springs
Comp Cams Modified retainers
Rollmaster double row timing chain
Deleted balance shaft
Yella Terra 1.6:1 roller rockers
Ported blower and lower inlet manifold
Custom rear U bend
LS1 Throttle body
LS1 MAF
63mm pulley on Yella Terra snout
Yella Terra billet fuel rail kit
Stock injectors (for now, see how it goes)
Custom 1 5/8" extractors
twin 2.5" into single 3" exhaust (2 muffler so it's not loud)
Trans:
Turbo 700
B&M shift kit
Corvette servo
2800 non lock up converter
B&M Quicksilver shifter
These are all new additions for this build, it used to be a T5 manual.
Diff:
HQ V8 10 bolt Salisbury (shortened)
3.55:1 gears
LSD
Shortened VN Commodore 28 spline axles
VN V8 Commodore 4 wheel discs and VN master & power booster.
That's about it.
roughly how much power are you getting at the treads?
also how is it compared to one with an 8, as far as performance and handling? id assume its a touch lighter in the front then one with an 8 does it handle any better?
