pic of when i had engine in the car and running
took engine out once again..
stripped engine down to inspect
engine has been very neglected old oil sludge baked on thick everywhere looks like it hasnt had a oil change in a very long time.. bearings were very warn, found a broken ring on a piston and some quite bad cam wear on a few lobes, o well dosnt matter its all getting rebuilt, engine is now down at my bros work, hes a engine machinist, getting hot tanked, steam cleaned then crack test, measure everything ect to make sure its all fine, not going overboard on the rebuilt, just basically building it a bit stronger for boost, get a cam grind to suit a turbo, roller rockers, head studs, metal head gasket, block o ringed (maybe), hypereutectic pistons, standard rods, arp rod bolts, new bearings, all new gaskets, high volume oil pump, bigger sump, plus all machining ect
