detox_nath83
Another VL Driver
- Aug 6, 2005
- 2,160
- 6
- 0
- Age
- 41
- Location
- Queensland(Sunny Coast)
- VL Turbo Commo
Car: 1987 VL Commodore
Engine: RB30E Converted to RB30ET(Turbo) All work done Myself and a mate Jason with a lot of swearing, clearance probs and beers drank with help verbally from Nackerz <---cheers bloke :beer chug:
Engine Mods: Cold Air Intake, T04E Turbo Journal Bearing Oil Cooled only on a Highmount Manifold, 3" Dump pipe to Cat, 50mm External Wastegate with a manual boost controller set at 12 psi with screamer plumbed in before cat then 3" Cat Back to Stainless 3" Turbo Tip, Front Mount Intercooler 600X300 X 70mm with 2.5" cooler piping, Powdercoated the rocker cover at work Flame Red, with a high gloss finish over top. K&N Panel Filter
Body: Black with Green Fleck (dont know color name or code) De-badged, New Front Lights, VL Brock Grille
Gearbox: Stock Auto Sludgebox Gettin tired Now Ha
Stereo: Pioneer Headunit, Pioneer 6x9 4 ways 450 Watt In rear, 3 way 6" 250 watt Clarion Fronts, 1 Dominator 1000 watt amp, 1 Audioline 600 watt Amp, 2x 12" Subs(Forgot make). and 1 12" Clarion 500 watt sub Caus 2 just aint enough
Interior Mods: Central Locking, Alarm , Aftermarket Steering Wheel, Berlina Dash Cluster, Calibre Boost Gauge, Oil Pressure Gauge and Type R Water Temperature Gauge
wheels: 225/50/R16 All round VT Clubby Knockoffs by PDW 16"
Suspension: Lowered 3" approx
Future Mods: 5 Speed Manual, 3" Exhaust Right Through(Done), Fix that crappy Intake for turbo(Done), respray bumpers, Make a Heatshield for turbo,gas struts for bonnet(Done), Turbo ECU(Done), Turbo Injectors Done,28 Spline LSD Diff, Disk Rears(Done), Turbo front callipers + DBA Slotted Rotors Fronts(Done), Oil Catch Can((Done)Up the Boost(Done)
Fix Ups: Bumper where stupid cow kicked it while away shooting, Front trim strip left side under light, Flaking Paint in engine bay and Under bonnet Painted(Done).
Conversion Pics are Here
Cheers Lads
Nath
like where the cow kicked my car
Yes Boot has had a Vac since pic
Amps are crappy brands, but does the trick drives stereo well(bleeding from the ears ahhhhh)
Cheers Lads
Nath
