my vs ss surges when driving and the tacho flickers. has it happened to you?
applez
bendigo
VS SS 5.0
i have tried many things, plugs, leads, oxy sensor, alt brushes, new injectors and still it surges and gettin worse over the last few months. causing it to be heavy on fuel. PLEASE HELP ME : (
SP00KSTER
VS UTE, HT MONARO REBUILD
mate my S3 V6 VS ute does this, i changed my leads and plugs which helped and now it only occurs every now and again, but i do have a miss fire that i think might be linked to the problem, Im thinking its my coil packs/ DFI module as every other component is in great working order, it does chew up a bit more fuel than a motor in perfect working order due to the miss fire but it's not real heavy on fuel.
GTP 85
291 hp @ the wheels
35
Murray Bridge S.A
MY04 WRX, VS SSenator & VS V6 track weapon
Just fixed a similar problem on my VN. Replaced the dissy as the clip that was holding the hall effect sensor had corroded, allowing the sensor to shift around everytime i hit a bump.
My symptoms: loading it up at low rpm it would cough and splutter then clear out, it would miss when hitting bumps in the road AND the tacho would jump 1000rpm when it did this
Now its all good
The1
A Memcal a Day Keeps..
QLD
www.eyeit.org
VS V6 Berlina Auto
as above go dfi
edit 5L as per below:spot on:
applez
bendigo
VS SS 5.0
any chance the computer is the problem or crank sensor? it doesnt stall, backfire or not start though
GTP 85
291 hp @ the wheels
35
Murray Bridge S.A
Just try swapping the dissy. It a 10 min job. If its not the problem, then you have crossed one thing off the list
SS 1998
shepparton, victoria
VT SS
ive got the same problem in my vt 5lt. sometimes its worst then other times.
and yer when taking off from a standing start it revs nearly drop 1500 rpm from round 3500 to 2000
ive tried a few things like leads plugs injectors.
think i mite try a the dizzy.
