My VX Calais Turbo
RED1M8
South Auckland
VX 383 turbo & VK Royale LS1
I made 387 rwkw @ 12psi with the same turbo:thumbsup: so there is more in it for those that want to push it a bit further
Solid8
47
VX Calais LS1 Turbo
Aah yes, I think I found some info on your car on the LS1 forum while I was doing research on what turbo to use for my kit. I wanted to push 12 through it, but didnt have a boost controller so I was limited to 9psi sadly. What exact spec T-70 did you use? Mine is a Q-Trim, unlisted specs on Master Powers site, but 69mm comp wheel and T4 exhaust
RED1M8
South Auckland
Mine was Q trim as well with a 1.0 devidded exhaust housing.
Have since upgraded to a Turbonetics TC78, but the Master power was certainly good bang for buck and never gave any problems.
Solid8
47
VX Calais LS1 Turbo
Sounds like the exact same unit I used. Ive been running it for a while now, zero issues, zero oil leakage past either seal, Im happy as with the bang for buck this turbo offers :)
Solid8
47
VX Calais LS1 Turbo
Here is a short video of some boost :)
H1GHROLLR
CHEMICALLY SUPERCHARGED
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
goes hard just spins the bags when you put the foot into it . . .watch the instant fuel gauge it goes straght up to 99.9
Solid8
47
VX Calais LS1 Turbo
Cheers fellas lol. That is just giving it a bit of mild throttle until she has some boost, then giving it some wide open throttle for a moment
H1GHROLLR
ROCKINGHAM,PERTH
VX CLUBSPORT R8 LS1
not bad for the money you spent . . . makes me nearly spew seeing as i just spent about 13 grand building a N/A ls1 and you pissed all over my 426rwhp
STEALTHY™
So Wet For You!
SA - The Roadworks State
Might want to blank the plates off the Dyno sheet since you went to the trouble of blanking them in the pics :)
