My VY Acclaim SerII
VYHDT
Donating Member
37
South-West Sydney
VY HDT
Get photos of the bits of the road that damaged your car if possible, put something next to it to show how big it is. Same thing happened to my mate, he took photos, got quotes for new wheels/repairing the existing ones n all that...council bought him 2 new rims :)
That's what I did :)
unregistered
39
03 VY V6 S2
how much was the chrome bonnet strip?
Zeussy
SSM11K
Central Coast
Gen-F Clubsport, Rodeo 2.8 TD 4x4
howd you go fitting that chrome strip? can you just tape it on or do you need the screw holes? ive wanted one for ages but seeing as its for the vz bonnet with deeper 'slits' in the bonnet i didnt think it would look good but looks great, just hope i can get away without drilling holes in my bonnet if i wanna change it later.
cant wait to see it with a badge haha
The Chrome strip was easy-ish to put on - with the right tool. They are attached by 7 or 8 screws that screw into the under side of your bonnet - no drilling required.
Its removable and you wouldn't know it was there from the outside. You need to attach the bracket that holds it to the bonnet; then screw the Chrome part on afterwards.
Theres hex shaped holes in the skeleton/re-inforcement of the bonnet , around the latch area.
You need to get the special Nut inserts from Holden, and install them with a NutSert tool, basically a pop riviter, but with a threaded rod attachment that screws into the nut, and compresses it to sandwhich the nut around the bonnet reinforcement.
Not sure if they're cheap, or easy to come by, but being a Mechanic work had one so I borrowed it over the weekend and voila!
Maybe see if a local Workshop has one you can borrow, or will do it for a drink or two?
This one is off a VY Calais, (as I have a VY bonnet) but you can find VZ Calais ones easier, there seems to be more of them around for some reason? I rekon they would suit the VZ better because of the ridges that run down the bonnet, so it sort of fits in nicely.
Yeah, will try and get some. One of them has been filled - but took them over a week to fill it. Not sure on the other one as I haven't been back down that way since?
Sounds like a plan, who at the council did you send it too? Just like a general enquiries email/postal address?
Wouldn't happen to have that letter you sent them close by would you???! :) lol.
I think around $150, then I had to buy the screws and Nutserts from Holden. Around $15-20 for everything.
where did u get the vy crome strip from i cant find any on ebay
On ebay, it was second hand - but like new. They pop up every now and again, just gotta keep an eye out.
Took me a few months to get this one - there was one other that I saw and bid on, but got outbid on as I didn't want to spend that much - around $100.
Then I saw this one and was like "I don't care, its mine..." :p
sweefu
VY Berlina V6 / R31 Skyline
Man thats a massive pain with the wheels! What size tyres were you running? If you keep the 20's on go something a little wider, might protect them a bit more
TMM
OEM+
VIC
VY Berlina S2
+1. Looks like the pothole broke the bead because the tyre is too stretched on the rim. Bead broken = no air = wheel gets farked.
Zeussy
SSM11K
Central Coast
'ken oath. Stupid roads. 225/35/20. Can't really run any wider with that offset rim on the fronts, the inner edge of the tyre scrubs on the spring saddle/strut/tower...
Nah, looks like **** roads, pot hole buckeled the rim = which broke the seal between the tyre and rim = which lead to farked tyre. Tyres weren't that stretched, 225 on 8.5" rims.
If the council maintain their roads there wouldn't be an issue...? I mean, if the RTA can keep their main roads (half) maintained, council should be able to do their roads...
sweefu
225/35 on an 8.5" rim is a fair stretch, at minimum the rears should fit a 245/30? That's the 'legal' size, usually fits quite well. Still a massive pain though mate!
Zeussy
SSM11K
Central Coast
Legal? Cars engineered with these rims and tyres on it?!
Can get 245's on the back, but I like to put the old fronts on the rears when I get two new tyres on the front. lolwut?! :/
Anyway, next pic you see should look something like this... :D
And a big thanks to Richie for the chop! Made my mind up.
Look good in white too! :confused:
Wombles
Cars cost too much.
Ive been wondering about this thread.. Sorted those wheels out yet?
