My Vy Commodore Radio turns on full volume
Boothy
Vn Wagon, VY Commodore
Hi There,
Just after a little help with my factory fitted radio in my Vy commodore. It regulary turns on full ball
and occasionally will die for a second or two when you flash high beam. The main thing that annoys
me is the volume problem, so any help or advise on this would be appreciated.
Should also add the head unit is a Blaupunkt and has had a sub and amp added.
tallvy2berlina
VY2 Berlina hail damaged
what amp have you added as i am looking to add one my vyII berlina
Jonno
Vic,
Comment above that's not really relivant
The stereo will cut out with headlights or if it's up too loud Cos it's drawing so much power and the sub is sucking alot of power, pretty sure that a capacitor(how ever theor spelt) between battery and amp will fix that
Sterio on full blast;
Does it happen randomly or just whn u turn the car on does it go full straight away?
Boothy
Happens totally randomlybut only when you first turn it on. You turn it on sometimes and it will be fine and other times will come on full blast , turning on and off a few times can usually sort it out, but totally annoying
