Totally different setup and problem. VEs suffer from debris sticking to the encoder ring on the smooth surface on the back of the wheel bearing that the sensor reads off. Earlier commodores had the toothed ring next to the diff that the sensor read off which either had dirt fill the gaps up between the teeth or dirt in between the teeth and the sensor or the wrong spacing between sensor and wheel.
