goon1337
- Nov 10, 2022
- 11
- 3
- 3
- Age
- 33
- Location
- Newcastle
- VE 3.6 SIDI
Yet another ABS / Stability control fault thread.
I know there's a few of these already, just wanting to know if anyone has had the fault appear in the soecific conditions that mine appears to be happening under and if they've found the cause before I throw more parts at it.
I've got a VE sv6 manual ute that keeps throwing an abs fault. I've replaced the rear sensors, which seemed to help a bit, but it's still occuring.
It seems that it usually occurs when changing gears slightly heavily. Like when downshifting to engine brake or on slightly spirited up shifts. It does occur occasionally under heavy braking or when traction breaks, but mainly on gear shifts.
This leads me to believe it might be the module itself in my case.
Has anyone had the same ser of symptoms?
Cheers.
Cheers.
