SuperHoon
- Jun 21, 2017
- 27
- 7
- 3
- Age
- 33
- Location
- Traralgon, Victoria
- VFII Redline Ute
Hey Guys,
my VF broke down in the driveway the last week with what looked like a stuffed clutch switch. had to get it taken on a tilt tray to the dealer. thought it would be a quick job but this car must be cursed. its a June 17 build.
further investigation revealed:
Kinked breather in the battery box area.
Battery spewed acid underneath carpets causing damage to paint and carpets behind passenger seat so needed a re-paint and new carpets.
Battery to be replaced.
Corrosion in body harness so harness to be replaced.
Charge output on alternator to be checked (possible overcharging).
i personally haven't seen any of the damage it has caused but if i were you i'd be checking the breather for the battery in your ute. you dont want the headaches that this could cause down the track.
i obviously got the build where the guys couldnt give a ****.
