VR.Ute.LovIt
- Feb 18, 2021
- 10
- 4
- 3
- Age
- 38
- Location
- Burpengary
- 1995 Holden VR Commodore Ute
Gidday peepz, thanks for checking into my post
Just like bro know if anyone has an answer to my crank issue as it seems like everywhere I read within the vehicle repair manuals that have the LEO 3.6 litre Alloytec Engine fitted to it and in the manuals they all state a key way for the crank yet mine seems to me that maybe it had a key way once upon a time and somewhere along the way it has failed and looks to have been cut out? I am unsure as to how to fit the balancer back on the crank as even it has no key way whatsoever and so I don’t know if it is going to be an issue for the engine with regard to testing and diagnosing timing and tune up in future as I won’t be able to throw on a timing light in future given the balancer wouldn’t be in it’s precise location with relation to crank position when mounted??
Can anyone please confirm this is a broken keyway and is anyone able to share with me any info about this and or what I should do and procedures to follow to mount the balancer to the crank correctly? Much appreciate your help in advance
Thank you
I have attached pictures for better understanding of this concern I have
2nd issue is that I am stuck unable to release the fuel line connector with the disconnect tool I have that is a four way style tool also in pictures, my tool is too big and I don’t have access at the moment to the disconnect tool that I need and I was hoping someone might be able to share with Me any other way I may be able to safely disconnect the fuel line so I can remove the rail and keep going with the work I have cut out for me as it is so any possible way I can do this would be greatly appreciated
Many thanks again in advance for any input and hope to expand my knowledge on this vehicle as I have bought it recently very cheaply through a friend and I am doing some very in-depth maintenance work that was neglected for a long time and I would like this car to be reliable for me so I am doing as much work to it that I can think should be done and if you have any input on this too I’d also like to hear your thoughts on what I should take care of while here as well
Nathan
Thank you
Nathan
