shifty6
- Aug 1, 2008
- 129
- 2
- 0
- VS Exec 5spd
Hi everyone,
Having trouble with my vu ute, was driving home few days ago, it started kind of dying, but wouldn't stall completely, just like a really bad stumble or a miss. Felt like whole engine momentarily dying though, not just one cylinder. Seemed worse under load. After a couple of k's it would only crawl at idle, and then died altogether.
Now it seems like if I prime it, it will start and run for a second then die.
I can hear the pump priming, it has injector pulse when cranking, has spark, coil pack resistance is fine on both primary and secondary sides, fuel pressure is 35psi when cranking. Replaced fuel filter. Don't know where else to look. Thinking immobiliser but it has injector pulse? Unless ecu lets it fire and then cuts injector it's hard to tell.
